Skimmer weirs, at least the Sta-Rite/Pentair (U-3) have, in the past 5+ or so years, have become increasingly thin. I assume, like you said, that they are a pocket of air as opposed to the "tried and true" Styrofoam. If the weir floats when the pump is off, then it is probably ok. It should hover between the floor of the throat and the waters surface. You can try adjusting the water level in the pool to increase/decrease that amount of water in the throat that the weir has to deal with. If you decide to get an aftermarket weir, it will have Styrofoam, and perhaps perform better for you.
