Re: Pentair Intelliflo VS Pump operational time
First, GPM and turnover is irrelevant to run time so don't even worry about that.
The amount of run time you need is mostly determined by how clean (dirt free) you want the pool which is subjective and can only be determined by your own definition of what a clean pool looks like. So unfortunately, there is no one size fits all answer to run time.
But most pools don't need more than about 4 hours per day of run time. A split run time is more effective at skimming debris if your controller allows for that.
The most efficient (gallons/watt-hr) speed for the Intelliflo is around 1000 RPM. So you can start with about 6 hours of run time at 1000 RPM and see if the pool stays clean. But unfortunately, the flow rate is also quite low so the skimmers may not capture enough debris so you may need a higher speed for a short period of time for just skimming.
Some experimentation may be required to optimize the run time.
