Thread: What are the measurements for a easy set solar blanket
    Jun 2013
    Near sunny Buffalo NY
    Default What are the measurements for a easy set solar blanket
    My little 30" x 10' Intex easy set pool has been put away for some time and it has been awhile since I posted here. I was considering getting a larger pool this coming summer but decided to just wear this one out before upgrading so will be going back up this summer. I want to cut a new solar blanket for my pool in the spring and remember a link in the forum that showed the measurements of the easy set pools but I cannot find the link anymore. If I recall correctly the opening for my pool was only around 8' or so. Some help please with the correct size and maybe the link to the easy set measurement?
    Thanks,
    Larry
    Jun 2013
    Default Re: What are the measurements for a easy set solar blanket
    No hurry. The pool won't be going back up til the 4th of July or so. :-)
    BigDave's Avatar
    8 feet should be good. If it's too big, you can trim it with scissors - be carefull with the shears or you'll be upgrading that pool a little sooner.
    Jun 2013
    Thanks. I'll be real careful and cut the the material outside of the pool. :-)
