Thread: its winter 60 degrees pool is clean but.......
    May 2013
    Concord,ca
    Default its winter 60 degrees pool is clean but.......
    Hi there my pool is clean, its winter in California 60 degrees at most I tested my pool no chlorine. Do I still need to add chlorine even now? Or should I wait till spring. I got some algae last year and I don't want that to happed again. I am ready to do whatever it takes. I added a gallon last week bot it doesn't show. Thanks everyone Dave
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    Default Re: its winter 60 degrees pool is clean but.......
    I would suggest raising your chlorine level to suggested shock levels for whatever your CYA level is. See the "Best Guess Table".
    May 2013
    Concord,ca
    ok thanks Carl
