Thread: Question on Replacement Cyanuric Acid Reagent
    Jul 2012
    Default Question on Replacement Cyanuric Acid Reagent
    I have a question regarding replacement for my Cyanuric Acid Reagent.
    I am currently using a HTH 6way tester and I quickly ran out of the Cyanuric acid Reagent. I cannot find a HTH replacement.
    This is my HTH 6way tester from Walmart.
    This is the Cyanuric Acid Reagent tester.
    I then found this Taylor Cyanuric Reagent replacement on Amazon.com.
    Question is can I buy the Taylor Cyanuric Reagent and still use my HTH tester tube and the #9191 bottle?
    Jul 2012
    Default Re: Question on Replacement Cyanuric Acid Reagent
    Yes.
    The HTH kit shown is a private labeled Taylor kit, that uses standard Taylor reagents.
    Thank you very much.
