Results 1 to 10 of 17
Thread: New Owner - Need Help-- Please
    michladny is offline ** No working email address ** michladny 0
    Default Re: New Owner - Need Help-- Please
    Hi there...
    THANKS for the start of good info--much appreciated.
    As of right now my CRAPPY strips have me in perfect ranges so I believe I am close either way (beginner's luck I am sure)!!! When I started adding chemicals I went through a WHOLE bottle of PH+ and 2 bags of conditioner/stabilizer cause I added the chemicals according to the "pool" place directions on one of the boxes.
    So let me get this straight---
    1. PH can be increased by Baking soda? I know I read that the trichlor decreses the PH.... I use the tabs...is that NOT GOOD?
    2. With what do you adjust alkalinity --- ?
    3. The CYA is adjusted by the use of stabilizer and the constant use of the chlorine tablets? How does that get so high if the chlorine is used up from what you are putting in the pool? Pool places do not tell you that tablets will raise CYA (I know to sell chemicals) but if CYA shouldn't get too high then that is crappy of them!!!! I was informed that you only need to add the stabilizer once a season? How would you decrease the CYA?
    The trichlor tablets I use I place two in the floater and that lasts a few days...(the pool pace said to add FOUR and replace when dissolved-that seems like an awful lot!!!!) I have had the pool filled and open for the past three weeks (only swimming last week and now we had some rain/storms)and my numbers have looked pretty good. I believe someone told me that HTH makes a chlorine tab with algecide in it (or do they all have that in there since it is chlorine)? I also saw the HTH tabs have copper so I shouldn't use them?
    4. Wll I EVER feel confident about taking care of this POOL?????
    This CYA confuses me sooo much.... If I use tablets (trichlor) I can add lots of stuff I do not need? If you test faithfully and all is well then why couldn't you continue to use the tablets? Why is bleach so much better? CYA too high does what?
    I have been reading this site/forum for the past three hours taking notes !!!!!!
    Michelle
    No. pH is increased by Borax, and decreased by trichlor or dichlor, or by muriatic acid or dry acid. The tabs are not necessarily bad, but if you're having a hard time keeping your pH up, then losing the tabs is the first thing you'll need to do to correct it. The tabs also release CYA into the water as they dissolve. You need some CYA in order to protect your chlorine from the sun, but you need to be aware that as your CYA level rises, then so must your "baseline" level of chlorine. See Ben's Best Guess Chart at the top of the Chlorine forum for a guideline you can use for required chlorine amounts based on your CYA level.
    2. With what do you adjust alkalinity --- ? You
    You raise it with baking soda, and you lower it by using acid to lower alk til your pH is around 7.0, then aerate the pool to raise the pH back up without again raising TA.
    The chlorine is used up in the pool, but the stabilizer is not. The only way to lower the level is to drain/refill.
    You're right, and that's the purpose behind this forum.
    Drain/refill.
    The trichlor tablets I use I place two in the floater and that lasts a few days...(the pool pace said to add FOUR and replace when dissolved-that seems like an awful lot!!!!) I have had the pool filled and open for the past three weeks (only swimming last week and now we had some rain/storms)and my numbers have looked pretty good. I believe someone told me that HTH makes a chlorine tab with algecide in it (or do they all have that in there since it is chlorine)? I also saw the HTH tabs have copper so [B]I shouldn't use them?
    The copper that hth has added to their tabs is an algaecide, but copper is the culprit when you have green hair and nails, and also tends to stain pools. Don't add copper to your water, it creates LOTS more problems than it solves.
    Yep, it just takes time.......
    See my explanation above.
    Because bleach only adds chlorine, NOT extra CYA, Ca, or anything else.
    Requires you to maintain high chlorine levels to ward off the algae.
    Hang in there, it seems like a lot of info, but it will all make sense eventually!
    Hope this helps!!
    tulsa, ok, usa.
    Quote Originally Posted by michladny
    Michelle
    When you get it all squared away, and all you have to do is test every day, and add part of a bottle of generic bleach every other day, and it always looks perfect you will be very confident. It's really not that hard, and the advice here is priceless.
    No,
    it really isn't that hard. Once everything is in balance, you'll probably need to add some bleach every other day--probably between a quart and a gallon, but how much, I cannot say.
    It all seems SO confusing but it's not. There's two things that matter: Chlorine to sanitize your water, and pH to ensure it's neutral and not too acidic and not too basic.
    All total alkalinity is for (and the name is misleading to the laity) is it's a buffer for the pH--it keeps pH stable and from bouncing. You need it, but too much is a problem
    CYA/Stabilizer's job is similar, but for chlorine. It's a buffer that keeps chlorine from breaking down too fast, especially when exposed to sunshine (without which summer isn't summer). You need CYA, but too much is a problem
    Calcium is for concrete pools, not vinyl ones. It saturates the water with enough calcium to prevent it from leeching out of the concrete or plaster. Not an issue with vinyl. It's only a problem if it's too high.
    Other stuff: Most if it you should NEVER need if you follow the procedures discussed here.
    There's algaecide--most are copper or ammonia-based or foam and we recommend you NEVER use them. The only algaecide we recommend (and only as a preventative) is Polyquat 60%.
    There's clarifier and yellow-out and flocculant--(Polyquat
    acts like the last but otherwise most of us NEVER use these)--and pool stores push them.
    There's sequestering agents--this is only if you have problems with metals--maybe one in 100 of our members EVER need this--if that many.
    There's phosphates and phosphate removers. This is the pool store biz's latest scare tactic to sell you very expensive removers. Forget about it! Unless EVERYTHING we suggest here doesn't work, AND you have very high phosphate levels, that may be your answer--I can think of maybe 2 or 3 cases where it WAS necessary in the last 7 years.
    Finally, there's the chemicals you use. You can keep your pool indefinitely sweet and clean using the BBB's--Bleach, Borax and Baking Soda. Add to that Muriatic Acid and CYA(stabilizer) and that's IT!!!!!!
    But there's a catch--you have to have a good test kit, and use it regularly. Anything from the cheapee WalMart HTH 5-way test kit (THE bargain in test kits) to PoolDoc's PS-234 (the best home-owner's kit--and still very reasonable in price) will, if used properly keep you with sweet, safe, clean, BEAUTIFUL water.
    Go to PoolSolutions.Com and start reading. Read EVERYTHING--then read it again...I went from totally lost 7 years ago to always having a "happy" pool. I was confident enough to go from a 4,000 gallon Intex 15' round donut (which doesn't owe us a dime from all the fun we had in it) to a 20,000 gallon 40x16 custom FantaSea with built-in, "invisible" solar heating. I credit PoolSolutions.com and this forum for my education.
    Ok - THANK YOU ALL FOR THE INFO---- I FEEL A LITTLE BETTER!!!
    As far as the kit, I am going to get one today!!!
    My levels look ok but as of right now I can take the tabs outta the floater and start testing to use bleach...correct? I will test daily so I can learn what I will need to keep my levels in check
    Adding the bleach should go in front of return and not in through the skimmer?
    I am on my way to Walmart (bleach, baking soda, and Borax) and then I am going to stop and get a Taylor test kit from the pool store (unless I can find one at Walmart or Target).
    THANKS AGAIN EVERYONE!!
    Michelle
    mbar's Avatar
    Ashland, PA
    Carl,
    Thanks for the post, I am printing it out to give to a friend of mine who just filled his pool, and has the dreaded test strips! You explained everything in a concise, complete way - You should put it as a sticky somewhere!
    Northeast PA
    Default Re: New Owner - Need Help-- NUMBERS
    I took the water to get tested and here is what I got:
    Sat Index 0.26
    Total Dissolved Solids 0
    Free Chlorine 2.4
    Total Chlorine 2.5
    Combined Chlorine 0.1
    pH 7.9
    CYA 53
    Copper 0
    Iron 0
    Total Alk 100
    Adjusted total Alk 81
    Calcium Hardness 10 (they said it was 0 but put 10 in for the computer)
    Temp 75
    They wanted me to raise the Alk w/ 4 lbs of Alk increaser and add 25 lbs of Calcium to the pool
    Now one place told me (where I bought the pool that I do not need Calcium for an above ground pool) and this place (reccomended by MANY, MANY people said I do need some calcium) WHICH IS CORRECT?????????? I thought my Alk was fine at 100????
    Sat Index 0.26
    Free Chlorine 2.4
    Total Chlorine 2.5
    pH 7.9
    CYA 53
    Copper 0
    Iron 0
    Total Alk 100
    Temp 75
    No! NO! NO! NO! NO!!!!!
    That advice is completely and totally wrong, it will not help your problems, it will only cause more! They are just trying to sell you expensive chemicals....
    "Total Alkalinity Raiser" 4 lbs--$10. Ingredient: Sodium Bicarbonate 100%
    Arm&Hammer Baking Soda, 1 lb $.89 Ingredient: Sodium Bicarbonate 100%
    Same stuff. But your Total Alk is 100ppm WHICH IS PERFECT!!!!!
    Sure, they want to sell you calcium--it's expensive and it gives them lots of profit. It does NOTHING for a vinyl pool. I don't care if the pool store clerk says he swears on his saintly mother's head you need it. If he says if you don't need it, he'll commit Hari-Kari, then hand him a short samurai sword and tell him to go ahead. YOU DON'T NEED IT!!!!!
    Calcium is SOLELY to prevent concrete and plaster pools from leeching calcium out of the walls, weakening them, into the water. By saturating the water sufficiently with calcium you prevent this. But Vinyl doesn't contain calcium and it doesn't leech it into the water, so you DON'T need calcium. I find, when I know EXACTLY what a chemical does, NOBODY can talk me into putting it in if I don't have the problem it addresses. So now you know why vinyl doesn't require calcium levels and even if a million people recommend this store, they are still WRONG.
    Your pH is a bit high, but you don't need much acid to lower it--and you can leave it if you want and it will be OK.
    I'd raise chlorine levels, but you can use bleach for that. If you pool is clear, you are probably OK. But if it's green, you need to go into algae-fighting mode, and there are thousands of posts on that.
    Boy! I really HATE these pool store folks who mislead decent people with this garbage!
    Quote Originally Posted by mbar
    Carl,
    That's very flattering of you to say. There already was a sticky in the Chlorine and Chlorinating forum that I had done and Watermom put up, but I added this one to that so if one isn't clear to newbies, maybe the other is...cuz I'm too lazy to actually sit down and rewrite them as one...
