Re: Trident UV sanitizer
UV lamps in residential pools at recommend water flow rates output a fluence (amount of UV energy radiating from the lamp over an area) of around 30 mJ/cm2 (some are 40 mJ/cm2). The sun outputs around 300 mJ/sec/cm2/nm (yes that's per second per nanometer of wavelength) in the UV range below 400 nm down to around 340 nm falling off to 150 at 320 nm and then rapidly falling off towards zero (30 at 310, 2 at 300 0.03 at 290) due to ozone absorption of UV in the atmosphere.
Of course, the UV lamps output at lower UV wavelengths that are effective for disinfection, but the sunlight nevertheless has UV in the range that breaks down chlorine and when chlorine breaks down it forms hydroxyl radicals that are very powerful oxidizers. So while the UV in sunlight should not be seen as any form of supplemental disinfection, it most certainly can be seen as a form of supplemental oxidation. It helps in residential pools, but is not enough to make a substantial difference in heavier bather-load pools (i.e. commercial/public).
Since chlorine is the primary disinfectant and in outdoor pools is also a reasonable oxidizer, the only purpose of UV (and ozone, for that matter) would be in inactivating chlorine-resistant pathogens such as Cryptosporidium parvum. However, this pathogen is not found in the environment and would only be introduced into a pool by an infected person (via diarrhea). In indoor pools, a UV system can be helpful even for a residential pool.
