Results 1 to 10 of 11
Thread: CC reading
    Sunny32504 is offline ** No working email address ** Sunny32504 0
    dallas,texas
    Default CC reading
    How do you get CC reading. Also what do I need to check to make sure my pool holds chlorine longer? I need education on the pool balance readings and how to keep my pool balanced to which it will be easier to maintain . I have an 24' round AG vinyl liner which is about 13,500 gallons (think)I have an algea bloom at the moment so what I have done was poured 3 gallons of bleach and now I am going to let it filter until tonight about 9:00. I don't like leaving it on all night right now with the skimmer basket getting full as fast as it has and worried my cartridge filter might build up pressure over night . could someone help me get this thing clean .I have a pile in the middle of the pool which is sticks and algea is what it looks like. I have sweeped my sides of the pool and as much around the outside of that pile in the middle. I can't get in there to stir that up with the chlroine up as high as it is right now.
    mas985's Avatar
    Pleasanton, CA
    Default Re: CC reading
    For CC reading you need a kit the measures it like Ben sells on poolsolutions.com. Also good for other information on keeping a pool balanced.
    In order for folks to help you on this forum, you need to post your numbers:
    FC (need Ben's kit for this)
    TC (any old kit will give you this)
    PH
    Alkalinity
    CYA (probably why you cannot keep chlorine in the pool)
    Mark
    dallas,texas
    How do i check CYA I will go check my others now after I clean my cartridge one more time.
    mas985's Avatar
    Pleasanton, CA
    If your test kit cannot do it, your best bet now is to have a pool store check it for you. They will do a full test for you and probably recommend buying all sorts of stuff you don't need. However, you may need CYA and if the test comes up with <20 ppm, you may want to consider buying some while your there.
    Also, if you need to clean out sticks and large stuff, a leaf rake works great.
    Mark
    dallas,texas
    Okay here are my readings
    PH 7.2
    Alk 110
    CL 0.6 (Basic 4 Test Kit)
    I cleaned my cartridge and put in 1 more gallon of bleach. I guess with the algea and the 94' weather today it sucked out all the bleach I put in at 12:30 today and it is now 4:30. Should I be using more bleach? My kit has chlorine 3.0 , 1.5 , 1.0 , 0.6 and 0.4 I am at 0.6 would the highest mean 3.0 ppm? If so I need to be higher than that to kill this algea if I remember thru past threads. Thankyou for the response . We are so reading to vacumm and swim.
    Yes, it needs to be WAY higher than that. How high depends on your CYA reading, which you didn't give, but even with zero CYA you need to get your Cl to 10-12 ppm and KEEP IT THERE by testing 2-3 times daily and adding enough each time to go back to the 10-12 level.
    janet
    dallas,texas
    I am now going to the pool store but I don't let them people sell me out. I had this pool clear without there chemicals last year and I am determined to do it again. They already tried to sell me some down and out , yellow out or something like that to help drop everything overnight to the floor this morning when I went for a stinkin leaf net. I told them no I will get it out. Then he did recommend me to shock it with 4 pounds of shock because I told them I was battling some algea bloom. I won't buy that stuff for 12.95 for 4 pounds. Thats like gas prices in the summer time to get my pool to run .LOL
    The faster you can get the pile of stuff out of the bottom of the pool, the faster it's going to clear--you need your chlorine to be working on the algae, not on the sticks that you can manually remove.
    POst your numbes, and we can help you from there.
  1. Low Pressure reading
    By handy1 in forum Pool Equipment & Operations
    Last Post: 06-24-2012, 01:40 PM
  2. I cannnot get any FC reading???
    By Truckman in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-24-2011, 06:57 PM
  3. False CYA reading?
    By ChuckD in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-31-2006, 03:21 PM
  4. FC reading
    By newtopools in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-19-2006, 10:22 AM
  5. CYA reading w/new kit
    By wipple in forum DPD-FAS based testing
    Last Post: 07-09-2006, 09:30 PM
