Results 1 to 10 of 11
Thread: CC reading
    mas985's Avatar
    Pleasanton, CA
    Default Re: CC reading
    For CC reading you need a kit the measures it like Ben sells on poolsolutions.com. Also good for other information on keeping a pool balanced.
    In order for folks to help you on this forum, you need to post your numbers:
    FC (need Ben's kit for this)
    TC (any old kit will give you this)
    PH
    Alkalinity
    CYA (probably why you cannot keep chlorine in the pool)
    Mark
    Sunny32504 is offline ** No working email address ** Sunny32504 0
    dallas,texas
    How do i check CYA I will go check my others now after I clean my cartridge one more time.
    mas985's Avatar
    Pleasanton, CA
    If your test kit cannot do it, your best bet now is to have a pool store check it for you. They will do a full test for you and probably recommend buying all sorts of stuff you don't need. However, you may need CYA and if the test comes up with <20 ppm, you may want to consider buying some while your there.
    Also, if you need to clean out sticks and large stuff, a leaf rake works great.
    Mark
    dallas,texas
    Okay here are my readings
    PH 7.2
    Alk 110
    CL 0.6 (Basic 4 Test Kit)
    I cleaned my cartridge and put in 1 more gallon of bleach. I guess with the algea and the 94' weather today it sucked out all the bleach I put in at 12:30 today and it is now 4:30. Should I be using more bleach? My kit has chlorine 3.0 , 1.5 , 1.0 , 0.6 and 0.4 I am at 0.6 would the highest mean 3.0 ppm? If so I need to be higher than that to kill this algea if I remember thru past threads. Thankyou for the response . We are so reading to vacumm and swim.
    Yes, it needs to be WAY higher than that. How high depends on your CYA reading, which you didn't give, but even with zero CYA you need to get your Cl to 10-12 ppm and KEEP IT THERE by testing 2-3 times daily and adding enough each time to go back to the 10-12 level.
    janet
    dallas,texas
    I am now going to the pool store but I don't let them people sell me out. I had this pool clear without there chemicals last year and I am determined to do it again. They already tried to sell me some down and out , yellow out or something like that to help drop everything overnight to the floor this morning when I went for a stinkin leaf net. I told them no I will get it out. Then he did recommend me to shock it with 4 pounds of shock because I told them I was battling some algea bloom. I won't buy that stuff for 12.95 for 4 pounds. Thats like gas prices in the summer time to get my pool to run .LOL
    Don't buy anything from them unless it's a toy, or maybe a drop-based test kit (which actually would be a GREAT investment!) that measures FC, CC, pH, TA, Ca, and CYA. You don't need all that other stuff they want you to bu--all you're doing is lining their pockets.
    dallas,texas
    Here are the readings from Crown Pools .
    FREE CL - 3.29
    PH 7.2
    CYN - 23
    HARD - 325
    ALK - 110
    They told me this was a good balance
    For a clear, algae-free pool, those numbers don't look bad. However, with an algae bloom and a CYA of 20, you need to up your Cl to 12 ppm and keep it there until the bloom clears up.
    Did you by any chance get a testing kit while you were there? Clearing up an algae bloom is going to require frequent testing.........
