Results 1 to 9 of 9
Thread: My pool store is a better deal
    May 2013
    Concord,ca
    Default Re: My pool store is a better deal
    Carl I can buy an empty carboy its where to fill it
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    DD: Usually, if a pool store sells them, then they sell FULL carboys (they are blue) and you pay a deposit on the container. But when you buy another, you give them the empty and don't pay the deposit again.
    I've been cycling my 3 carboys for years now. It's also worth it to spend the $3-$6 for a carboy nozzle.
    BigDave's Avatar
    There's also a wrench available for tightening / loosening the cap and nozzle. You may not need it, but I no longer have the hand strength I once did and it really helps me.
    Channel Lock makes a great wrench that's perfect for it. Harbor Freight sells an oil filter wrench that should be perfect.
