Hey no worries, thanks for the time spent.
Heres the progress I have made yesterday early evening...
1. Doing a rinse on after a backwash. Seems to work, I read this another post so I have yet to try your method of doing kit multiple times.
2. Changed so that my incoming flow is only coming from the skimmer and outgoing flow is only going to 2 of the ports.
3. Added some algacide and shock.
I have decided to hold off on the acid wash, for now...
Questions/Observations
1. What about that gurgling I mentioned?
2. What of the low stream from the air relief valve on top of the filter? What is it suppossed to be like?
3. Is there some way to know if the system is behaving optimally? It seems better now, but how do I know if its performing? Especially that I found that if change the dial-a-flow controls, to only use some of the ports it works better. I want to be able to use all of them. So is there some type of measurement or something that I can do?
4. I am pretty sure that I have the 2400 model. The manual says its effective filtration area is 24 square feet. So for a 16b by 32 pool is this sufficient? I am freaking out now because the models you mention seem to be more powerful...
5. The most DE I have put in is 3 1/2 coffee cans full. This came from the bag of DE. It said that 1 coffeen can was 7/10 of a pound. For a 24 Square foot pool use 2 1/2 pounds. According to your post sounds like I should be adding a whole lot more, but not as much after backwash. It seem the instructions say to add 3 pounds. Probably been screwing those both up.
6. When I hosed off the filter elements I got everything... Took my time.
7. Still not sure about this acid wash thing. When I removed it came out rather easily. I dont think that the filters were retaining water, but I wasnt really looking at that.
8. It sounds like it would be acceptable to rinse the filter elements with a hose instead of backwashing? If thats the case I will try that the first couple of times. It didnt take that much water to do it. Maybe 25-35 gallons I would say.
9. Is acid washing something I could handle myself?
10. How much DE should I expect to use throughout a season? The prior homeowners left a little in a 10 pound bag from last season. I bought a 25 pound bag and was thinking that it would last a long time. Doesnt seem like it.
Will have more later.
J
