Page 9 of 14 FirstFirst ... 7 8 9 10 11 ... LastLast
Results 81 to 90 of 137
Thread: New build in South Texas
  1. #81
    Default Re: New build in South Texas
    I agree. 90 is bath water, not refreshing. Mid 80s is a much more pleasant water temp.
  2. #82
    Mar 2014
    Texas
    They are putting a Trex walkway in along the water
  3. #83
    What's that?
    Are you adding a dock of sorts?
  4. #84
    Mar 2014
    Texas
    I am calling it a walkway. On the other side of the low wall a feeding dock will be built so my wife can feed the ducks and Nutrias. There will be a floating ramp that will lead up to the dock.
  5. #85
    I was wondering if that critter in one of your pics was a nutria. Are the common around there?
  6. #86
    Mar 2014
    Texas
    They are putting the Caps on the perimeter walls and you can see the whistler ducks taking a break. Also the tree that my wife uses to feed the birds
  7. #87
    Mar 2014
    Texas
    There are a lot of Nutria around, my wife feeds them flour tortillas. The babies will tug at her pant leg for more
  8. #88
    Any pictures of that?
    . . . how are you gonna keep them out of your pool?
    I say that because my wife and I were swimming in a large mountain stream several years ago . . . until we discovered the bottom was COVERED with 'deposits' from another large rodent: beaver!
    You might also want to investigate what human pathogens your ducks (what species are they?) and nutria may carry. Beaver notoriously carry Giardia, which is very, very chlorine resistant.
    You may also want to consider replacing or supplementing your existing filter with a large DE filter. DE filtration will remove many pathogens and most protozoan cysts (like Giardia). Another option is to regularly treat your pool with polyquat (http://pool9.net/polyquat/) since it is a weak supplemental biocide, but an strong filter aid, and will enhance sand or cartridge filters capture rate on pathogens.
  9. #89
    Mar 2014
    Texas
    Pooldoc,
    Thanks for your thoughtful suggestions. The Nutria will not have access to the backyard pool. All those concrete retaining walls we put up will keep them out. When the yard is done I have some wildlife friendly deterrents that hopefully will keep ducks and other critters away from areas we don't want them in. Things like motion sensors in portable sprinklers heads I can move around, that activate and spray. A wolf silhouette with a moving tail, floating alligator head that you anchor in the water (geese hate alligators). And of course I have these girls.
  10. #90
    Dogs may well work. Enthusiastically, even.
