Sorry bowls not bowels. With the water falls and mist and evaporation that goes along with it, the need for replacement water increases. Replacing the water at a higher rate in effect acts as a counter balance to higher CYA. This just means I will go a longer period of time before I will have to drain and refill the pool to lower the CYA created by using chlorine pucks in the chlorinator.
The outlets at the end of the pool are the returns for the catch basin and the other are the returns from the skimmers
