Re: New build in South Texas
To be clear, I am not talking about evaporation by itself. I am talking about the mist created from the waterfall's (I have three) over the infinity wall and the other two mini falls as well as the mist and water disbursement because as the water falls the wind carries some of it away. If you have ever been to Niagara Falls that mist that is in the air is a direct result from the falls. This necessitates the need for more water. In effect I am replacing more water than a standard pool. It will not completely remove the appropriate CYA, but will delay the need for water replacement on a wholesale basis
