Thread: dry acid
    Mar 2014
    Default dry acid
    what is the advantage to using dry acid over liquid muriatic acid is the dry type acid safe on the chlorinator thanks
    Default Re: dry acid
    NEVER put ANYTHING in a chlorinator other than the recommended type of chlorine.
    Dry acid is easier to handle and store, and is perfectly fine to use instead of Muriatic
