I am a big time believer in polyquat.
I have a plaster pool that was mistreated by the original owners and it is rough in areas. I refuse to replaster the pool until it gets significantly worse... When you have rough plaster you have to be on the lookout for black alge. So I have used polyquat as algae prevention for three years. Knock on wood but I have never had a green, yellow, or black algae bloom...
I would add the whole 32oz bottle to your pool as an initial super dose of polyquat.
The only problem with polyquat is the price, normally $20... But I ordered some from Leslies on sale $7.33/quart last month now it is on sale under $5.00. So I ordered 5 more quarts.
Good luck.
. My pool has been beautiful ever since. I thank Ben and this forum everytime I go swimming
This should work if you can keep your cl level up throughout the day. Try to keep your filter running as much as possible to keep the water circulating and vacum as much of the algae as you can out of the pool. I would probably wait a few days after the 2nd dose of poly 60 before swimming.
