Will do.
thanks.
Will do.
thanks.
In-ground plaster rectangle.
Still waiting on the test kit.
I noticed my PH levels crept up again (of the chart). Would this be caused by the bleach?
Only if your chlorine stays high.
Bleach raises the pH while it's present as free chlorine, but once the chlorine is 'used up', the pH effect from that individual dose of bleach disappears. Test with OTO (clear => yellow drops) purchased locally (Walmart!). If the chlorine is high (dark yellow or orange), skip chlorine doses and don't try to adjust your pH. If the chlorine is on scale with the OTO comparator (<5 ppm), go ahead and adjust your pH.
Still waiting on my test kit. Hoping it shows today.......
I am not seeing the black (algae) change color or begin to clear. Could it be that its metal related?
To affect black algae, you have to (a) have high chlorine levels AND (b) brush the heck out of it.
Okay, I will up my brushing
someone needs to invent a power brush with a spinning head, Would make my life easier...
Look at the bright side ---- you will build up your muscles brushing!![]()
