To affect black algae, you have to (a) have high chlorine levels AND (b) brush the heck out of it.
Okay, I will up my brushing
someone needs to invent a power brush with a spinning head, Would make my life easier...
In-ground plaster rectangle.
Look at the bright side ---- you will build up your muscles brushing!![]()
Keep in mind, we haven't established that any of those spots ARE black algae. The most definitive test is to scrape some off with your fingernail, and smear it on a white card: black algae will smear dark green.
Brushing will make plaster wear through spots WORSE!
But, if you DO have black algae, a brush like thisPentair R111616 604A Algae Brush with SS Bristles, 6-Inchwill help.
NOTE TO OTHER READERS: Do *NOT* use a metal bristle brush on fiberglass or vinyl pools, EVER!
