Results 1 to 10 of 46
Thread: New Thread with my results of first test
    Mar 2014
    NC
    Default New Thread with my results of first test
    Ok... I know I should just look at the results and read what they mean instead of the shortcut of just posting them here, but I cant't resist. Besides, y'all ask for them when I got them.
    This is my first time with the Rockstar Test Kit, so let's see how I did...
    FC 2.8
    CC 0.4
    pH 7.4
    TA 70
    CH 250 (this one I might have lost count of my drops)
    CYA 40
    Ther ya' have it. Yay me!
    Default Re: New Thread with my results of first test
    Looks good.
    The CC=0.4 may be a testing error, or it may mean you need to keep the chlorine a bit higher for the next few days.
    TA=70 is a bit low, if you have a concrete pool, but fine otherwise.
    Mar 2014
    NC
    Correction: Cal Hard is 370
    I went back and retested :-)
    I will also do a Phosphate test tomorrow.
    I will start the search for a bleach supplier ASAP. I got nuttin' at the house right now.
    Unless you have a Taylor phosphate kit (preferred) or the Aqua-Chek . . . don't bother. The other kits I checked aren't accurate enough to be useful, unless your goal is simply to sell phosphate remover!
    Taylor Technologies K-1106 Phosphate test kit
    Hach Company 562227 Phosphate Test Kit (Aqua-Check)
    Mar 2014
    NC
    Unless you have a Taylor phosphate kit (preferred) or the Aqua-Chek . . . don't bother. [/URL][/B][/INDENT]
    Of COURSE I do... Would I disappoint you?
    QQ-Can I still use pool store chlorine until I find a good source for bleach? At this stage, it's just more convenient.
    Quote Originally Posted by Tom.B View Post
    Pool store bleach, purchased this year, should be fine -- heat cooks of bleach, but it hasn't gotten hot, yet. Still, Walmart bleach is likely to be fresher.
    Pool store tablets (trichlor) may or may not be OK -- read the label. Borates are a way to dilute the tablets so the store can make more $$, but they won't cause any pool problems at all. Copper is altogether different -- do not buy any chlorine with copper listed.
    Pool store dichlor should be avoided -- almost all of it is now badly diluted, and some of the chemicals used WILL cause problems.
    BigDave's Avatar
    FC 2.8
    CC 0.4
    ...Yay me!
    Yay you indeed. One thought, testing chlorine with a 10ml sample instead of 25ml will more than double the tests you get from your reagents.
    BigDave has it right. I saw that too. Use the 10ml setting for FC and CC instead of 25ml. There's NO need to test to .2 since .5 is easily good enough--and what most of us use for many, many years at a time.
    Mar 2014
    NC
    Howdy Y'all,
    It's been a while since my last post and I now seem to at least have a semi-grasp on what's going on. I can't thank you enuff for helping me.
    Currently, I am still using Leslie's Powder Plus (75%), Chlor-Brite (stabilized 55%) and 3": tabs by adding a one-pound bag every second or third evening. It's still easier for me to still buy from them, and compared to how much money I have given them over the past 5-10 years (many hundreds per week) I feel like it's still better for me at this stage. However, I am still trying to figure out terms like dichlor, trichlor, and hydtroflatulants ;-) to try and "own" my water chemistry. Still, my previous algae problem has yet to return and we are currently swimming in 75-degre water in NC. YAY!!!
    Here is where my chemistry currently lies:
    FC-4.5
    CC-1
    TA-7.4
    CH-390
    CYA-33
    Phos-125
    I guess if I had any question it would be about the combined chlorine. Should it be at, or near, zero all the time? Mine seems to stay around 0-1.5.
    I guess I thought of another one too: Should I try and bring the Stabilizer up some, or just let the Chlor-Brite and tabs sneak it up slowly over the summer?
    BigDave's Avatar
    I don't think the TA reading looks right, is it 74? Is the pH 7.4? If so, what's the TA?
    Power Powder Plus is Calcium Hypochlorite. With a Calcium Hardness of 390 (up 20 in a month), it's probably time to stop using Cal-Hypo. Have you found a source for bleach?
    I'm confused by the CYA reading, how do you get 33? Also confused because CYA dropped while using trichlor(tabs) and dichlor(Chlor-Brite) for a month. Probably want to review the CYA measurement.
    The consistent CC seems odd. Should stay about 0, maybe one drop - explained by the accuracy of the test. Do you cover the pool? Maybe rushing through the FC test? Maybe CYA is a good bit higher than 33 and FC of 4.5 isn't enough?
    I my experience, hydroflatus causes only giggles in well chlorinated pools - but usually only when it's observed.
