Results 1 to 10 of 46
Thread: New Thread with my results of first test
    Default Re: New Thread with my results of first test
    CYA dissolves SLOWLY. If you add CYA via the skimmer, and backwash or clean before you've run the pump 72 hours . . . you may lose the majority of what you've added.
    Mar 2014
    NC
    Can I continue to add Chlorbrite to the pool while I wait for the CYA to dissolve?
    What's Chlorbrite? Leslie's had several chemicals with that name.
    In general:
    1. Never, EVER let any chemical (except maybe borax) come into direct contact the cyanuric acid. Be especially careful with cyanuric acid + calcium hypochlorite.
    2. In general, as long as you follow #1 above, you can treat your pool normally while adding CYA.
    Mar 2014
    NC
    This: http://www.lesliespool.com/leslies-c...nular-bags.htm
    But that page say 99% while the bag says 55%. Oh jeez... I am afraid I know just enough to get me in trouble around here. Please bear with me while I am still learning.
    It could be 99% dichlor dihydrate which would be 55% available chlorine. If so, it's fine.
    If you're not sure, post the EXACT ingredient names & % you see.
    BUT . . . be sure to continue to use bleach, till you know. Don't let your pool go green, while you get answers to your questions!!
    Mar 2014
    NC
    I don't have straight bleach, yet. I hope to get to Wal-Mart today to stock up. I gotta use what I got ;-)
    Mar 2014
    NC
    That appears to be correct. So after 4# of CYA last night and a 1# bag of dichlor first thing this morning, here are the latest numbers. (and I think I am getting it right, but still need to go get bleach)
    Free Chlorine 6.5
    Combined Chlorine 0.5
    PH 7.2
    Total Alkalinity 90
    Calcium Hardness 390
    CYA (Stabilizer) 50-55
    (Copy/Paste from my spreadsheet... sorry)
    So I will check it again in the morning and see what, if anything, I lose at night and one more time tomorrow after work to check daylight loss. But I am feeling better about things. Algae seems to be gone (or at least under control) and let's hope I have the persistence to keep this up.
    Everything looks OK -- but be careful about using either baking soda (Alk Up) or soda ash (pH Up). With CH = 390, a heavy dose of either will precipitate calcium carbonate. Use borax to raise your pH, and you'll avoid that problem.
    Mar 2014
    NC
    Quote Originally Posted by Tom.B View Post
    FC=6.5 this morning. No overnight loss. (Water temp. 74 degrees)
    Mar 2014
    NC
    Ok, so here's the latest. I did a complete work-up just for the practice.
    Free Chlorine 5 (Loss of 1.5 PPM through the daylight)
    PH 7.2
    Total Alkalinity 80 (down by 10)
    CYA (Stabilizer) 55+
    It looks okay to me and seems to be trending to where you guys suggest it should be. I added another pound of dichlor (Leslie's ChlorBrite) for good measure... AND THEN... (see below)
    So... I went to do my brushing I do a few times a week and there is still a covering of yellow on the bottom. I have, over the past few years, played it off to be pollen, or sometimes thought that it could just be the early stages of green algae. However, now it's time to take a serious look at what it is and try and catch it sooner than later.
    I suppose I need to start a thread in the algae sub-forum (and will if you would like me to), but my question is: How can you tell if it's mustard algae? I don't see any high demands for chlorine, but I don't know if that is an indicator or not.
