Re: Do you think a solar pool cover needs to be "air-tight" to work at all?
The primary purpose of a cover is to reduce heat loss through evaporation which is proportional to surface area coverage. So having it air tight is not necessary. 90% covered will prevent about 90% of the heat loss through evaporation. Keep in mind though that a cover mainly reduces the evaporation heat loss and has a smaller effect on convection and radiation heat loss so even with 100% coverage, the pool will lose some heat.
