Pool is a swamp
Greetings, new participant here. I thought I posted this question already, but I'm not sure I followed all the rules. So I'm going to throw it out there again. I have a vinyl lined in ground pool that hasn't been opened in 6+ years. It was covered, but the cover ripped and it has been uncovered for several years. The water is very dirty and brown brown and there is 2 to 3 inches of debris, mostly leaves at the bottom. I need to try and open the pool and I've talked to several folks including my local pool store, who always wants to sell me expensive chemicals. I did buy two kinds of shock, one regular granulated and the other liquid with an algaecide. I also bought a scooping device which is how I know what is on the bottom. Did mention the frogs? Many frogs and tadpoles. I want to do this as efficiently as possible and with the least cost. Before I dump $100 of shock in my concern is with that degree of debris I feel like the shock won't do much so I am thinking I need to debulk the debris load. I have friends willing to help scoop for beers so I might be able to get some of it that way. There is also a lot of small particulate mater floating which of course is worse when we scoop. I haven't yet fired up the filter, that is another issue, but I think it will gag on this amount of particulate and I'm wondering if I should get a trash pump and pump the water through some kind of alternative filter device. I envisioned a trash can with drain holes that can drain into the pool with a layer of batting at the bottom to strain the particulate much like a big fish aquarium filter. I know I shouldn't drain the pool, vinyl liner and all and I do not want to have to replace the liner. It wasn't that old before we closed the pool. Can I use something cheaper than the pool store shock to shock the pool - bleach perhaps? I look forward to your comments, Cheers.
- You may not post replies
- You may not edit your posts
Forum Rules
