My bad -- didn't read your post very carefully, and made stupid recommendations (which I deleted) as a result. Sorry.
OK. Beer party tactics:
1. Make sure you have enough tools for your party goers to work effectively. If there aren't enough GOOD tools, the guys without tools (or with crappy ones) end up focusing on beer rather than leaves.
2. Get tools they can't easily break -- that means fiberglass poles rather than aluminum ones.
3. Attempt a quick clean up first: they will get a LOT more done, if they can see what they are doing. Try to start the pump pump on RECIRCULATE (filter bypass) using ONLY the skimmer. If you can, leave it on, and add 6 gallons of PLAIN household bleach for every 10,000 gallons of water. (Repeat as needed.) Once that's done, engage the filter IF you have a sand filter. Do NOT engage a DE filter; only engage a cartridge filter if you can easily clean it.
4. Get tools -- you probably can't get the tools you need, locally. Amazon links below.
5. Order a K2006, test your water, and make sure you don't have any serious water problems to resolve. Kit links in blue signature box. But, a local HTH 6-way (sometimes found at Walmart) will give you the info you need at present.
5. Good luck, and let us know how much beer it takes!
Purity Pool 18-Inch Lightweight Professional Leaf Rake, Tuff Duty ModelYou'll need leaf rakes more than you'll need skimmer nets. The Leaf Eater will NOT handle sticks and twigs, but will be very helpful for cleanup once you've gotten big stuff out.
Purity Pool PPSKM Pelican Pro 18-Inch Professional Skimmer Net
Hydro Tools 8375 8-16 ft Adjustable Commercial Fiberglass Telescopic Pool Pole[
Pentair R211046 185B Leaf Eater with Wheels and Brushes (Do NOT get a cheap Asian made version of this -- I've tried them and they are junk!!)
