Results 1 to 10 of 10
Thread: Pool is a swamp
    Apr 2014
    Greenville, NC
    Default Re: Pool is a swamp
    Sounds like I need to do my own testing. Will get the test kit. The calcium questions goes to the credibility of my pool store. They have recommended adding lots of calcium over the years and we had done it. They also told me I shouldn't use bleach as a chlorine additive because it would hurt my pool. Just seeking the truth. I think I need to reevaluate my relationship.
    We've heard all those bogus claims before, but not as much recently. When I first started PoolSolutions in 1996, I got 'nastygrams' from dealers on a daily basis!
    Your dealer may actually believe you need calcium. But, I suspect the bleach claim is a deliberate lie.
    Apr 2014
    richmond,va
    If okay I wanted to jump in here and maybe we could help each other and benefit from good advice. My situation similar to yours. Mine is 25k gallon IG. I added 8 lbs. of shock, ran filter 24 hours. Fixed several leaks so I thought I would start vacuuming. Plenty of suction, but I getting dirty water going back into pool. Backwashed, then rinsed
    but still dirty. Is that to be expected at this point. In other words should I continue as is, and after I have gotten up as much with vacuum as possible shock again? Or should I change the sand? By the way I estimate I removed several hundred lbs of leaves. And lots of frogs.
    18x34 22k gallon IG, Vinyl liner, Hayward sand filter, Hayward Chlorinator, Pentair Challenger 1hp pump, LA Spa.
    BigDave's Avatar
    zmanh:
    If you're looking for advice ib your clean up effort, you'll get better answers by starting your own thread.
