Results 1 to 3 of 3
Thread: cleaning tile
    Western NC
    Default cleaning tile
    Can anyone suggest the best way to clean tile above the water line? My tile seems to have the grout "leaking" out a bit, and in the past I've used a hydrochloric acid/water solution. I'm just wondering if there is a better product. The acid does the job, but I'm concerned it may damage the grout.
    Also, if anyone can give some insight into why my tile grout does this, I'd appreciate it as well! Thanks.
    St. Louis, MO, USA.
    Default Re: cleaning tile
    This year I used a light-duty power washer to clean the tile above the water line. It worked pretty well and sure didn't take long. You could even add clorox to the input of the washer, but I have not tried this.
    ~Rick~
    18,000G freeform gunite; PebbleSheen; Sta-Rite System 3 Cartridge; Sta-Rite heater; Polaris AutoClear Cl Generator; Polaris 380 cleaner
    waterbear's Avatar
    St. Augustine, Fl
    I have a pool tile scrubber that I got at the pool store. It can attact to a pole but I just use it by hand while I am in the pool. It has a fillable reservoir that release a cleaning solution through the pad and I use a mixture of tile soap from the pool store and muriatic acid in it.
    Works like a charm!
  1. Tile Cleaning
    By matthewnadeau in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-03-2013, 04:19 PM
  2. Tile Cleaning
    By sanddevil in forum In-Ground Pool Construction and Repair
    Last Post: 08-22-2012, 02:13 PM
  3. Tile Cleaning
    Last Post: 09-03-2011, 08:20 PM
  4. Cleaning and repairing pool tile.
    By JasonV in forum In-Ground Pool Construction and Repair
    Last Post: 06-04-2011, 12:56 PM
  5. Waterline tile cleaning
    By Sumo1 in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-16-2007, 02:30 PM
