Results 1 to 10 of 41
Thread: Excessive bleach consumption
    VOLDADDY is offline Lifetime Member Weir Watcher VOLDADDY 1 star
    Default Re: Excessive bleach consumption
    Yes, all of a sudden my 7 year old daughter is the most popular kid around now that the pool is open. Plus, we have a lot of family and friends over on weekends for cookouts. However, yesterday, only 3 people swam for about an hour, maybe less, all day. I still lost 5 PPM overnight, no swimmers, no sun.
    Katy, TX
    Did you have a sudden drop in your CYA levels at all? Also, with lots of young friends, i'm guessing there's a certain amount of ammonia being released which can lead to Cl demand. Kinda sounds like a CYA decomposition problem. Well, at least we know it's something in there, and not the sun. Keep at it, you'll get it eventually.
    Michael
    Tonight's test at 11:00 PM I have 5 FC. I was at 9 FC when I tested around 8 AM, and added 2 jugs of bleach, which should have brought me to around 14 FC. I added 3 jugs of bleach tonight which should bring me up to around 12.5 FC. I haven't had any sudden drop of CYA. I am out of the R-0013 now so I can't test my CYA until my new kit arrives. It was around 35, and I added the last of the CYA in my jug, around 2 lbs., on Sunday. I will be up bright and early and test and bleach again before work. I am amassing a lot of empty bleach jugs!
    6:30 AM test shows FC of 9, so I lost 3.5 PPM FC overnight. I added 2 jugs of bleach to bring it back up to around 14. Will retest after work again. I will throw my Aquabot in tonight and let it run, as there is a little dirt on the botom. Should I brush the pool down too? Honestly, I have gotten lazy on brushing. TIA.
    Katy, TX
    You're not the only lazy brusher here! I only brush if I see stuff on my walls. With the aquabot tho, you really don't need to brush since it does the walls for ya.
    6 pm test, FC 5, adding 3 jugs to bring to about 12.5 PPM. Whatever I am fighting is stubborn. I will test and add again before bed tonight.
    Any ideas or guesses what's going on? The pool isn't used much throughout the week, but something is eating away at the bleach. I have no CC's and no signs of any algae anywhere. My water looks great.
    duraleigh Guest
    Voldaddy,
    I would bring your Cl up to 15 +. Keep in mind I am an agressive (but accurate) bleach user so here's my thinking:
    Your last CYA test you said was 30-40 and you added 2lbs since (12ppm) so now you could easily be in excess of 50CYA
    Ben's "best guess" says if your CYA is that high, 15ppm is breakpoint and 20ppm is breakpoint for CYA of 60.
    Lastly, your Cl will start to diminish instantly...particularly since you seem to be working on something. You will probably never reach your intended target.....but you'll get very close.
    Do I think you're in danger of bleaching your liner at those levels?....No
    Will I buy you a new one if I am wrong?.....no, again
    My .02.
  1. Excessive air in system
    By monkeyratman in forum Pool Equipment & Operations
    Last Post: 11-23-2012, 08:56 PM
  2. Seems excessive
    By mfwade in forum General Interest
    Last Post: 06-27-2012, 10:44 AM
  3. Wow.... Bleach consumption cut in half with a solar cover
    By leejp in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-18-2007, 12:36 PM
  4. Update on excessive bleach consumption
    By VOLDADDY in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-18-2006, 06:37 PM
  5. Normal bleach consumption?
    By ShelleyAnn in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-09-2006, 11:18 AM
