Results 1 to 10 of 41
Thread: Excessive bleach consumption
    VOLDADDY is offline Lifetime Member Weir Watcher VOLDADDY 1 star
    Default Re: Excessive bleach consumption
    6:30 AM test shows FC of 9, so I lost 3.5 PPM FC overnight. I added 2 jugs of bleach to bring it back up to around 14. Will retest after work again. I will throw my Aquabot in tonight and let it run, as there is a little dirt on the botom. Should I brush the pool down too? Honestly, I have gotten lazy on brushing. TIA.
    Katy, TX
    You're not the only lazy brusher here! I only brush if I see stuff on my walls. With the aquabot tho, you really don't need to brush since it does the walls for ya.
    6 pm test, FC 5, adding 3 jugs to bring to about 12.5 PPM. Whatever I am fighting is stubborn. I will test and add again before bed tonight.
    Any ideas or guesses what's going on? The pool isn't used much throughout the week, but something is eating away at the bleach. I have no CC's and no signs of any algae anywhere. My water looks great.
    duraleigh Guest
    Voldaddy,
    I would bring your Cl up to 15 +. Keep in mind I am an agressive (but accurate) bleach user so here's my thinking:
    Your last CYA test you said was 30-40 and you added 2lbs since (12ppm) so now you could easily be in excess of 50CYA
    Ben's "best guess" says if your CYA is that high, 15ppm is breakpoint and 20ppm is breakpoint for CYA of 60.
    Lastly, your Cl will start to diminish instantly...particularly since you seem to be working on something. You will probably never reach your intended target.....but you'll get very close.
    Do I think you're in danger of bleaching your liner at those levels?....No
    Will I buy you a new one if I am wrong?.....no, again
    My .02.
