Results 1 to 10 of 13
Thread: What do I balance first - pool start up
    BigDave's Avatar
    Default Re: What do I balance first - pool start up
    Yay!
    Baltimore, MD
    Thanks for all the help. I do have one more question, what i the best way to increase calcium hardness? Mine reads around 140 and from reading this forum I see that for concrete pools (which mine is) its recommended to be above 200, but I have not been able to find the best product to use.
    48x14 rectangle in-ground concrete pool, 29k gallons, Taylor K-2006, 8.25% Clorox
    DE Filter Pentair FNS Plus FNSP60 (filter area – 60 sq ft, GPM 150, diameter 21.5”, turnover capacity 86,400 per 12 hours)
    Pump 1HP Pentair WhisperFlo high performance
    SWCG Zodiak LM3-24 (24 grams of pure chlorine per hour)
    Booster Pump Polaris Halcyon PB4-60Q
    "No pool store junk goes in my pool"
    You can chlorinate with cal-hypo for awhile and that will increase your calcium at the same time as adding chlorine. When you get your calcium hardness level where you want it, switch back to bleach.
