Re: replacement part for Hayward vari-flo valve?
I do have a main drain, and I will try that if it becomes a problem again. I just got back from the pool store and it turns out that at least part of the sticking problem was that the brushes on my vacuum head needed to be replaced. Chalk another problem up to inattention and operator error! So that is now fixed, and if problem persists I will open main drain a bit.
Thanks again!
16'x40' kidney / "nautilus" 25K gal IG vinyl pool; SWCG; Hayward ProSeries high rate sand filter; Pentair SuperFlo 1HP pump; hrs; Taylor K-2006C; utility water; summer: homemade solar disks; winter: mesh; ; PF:4.8
