Thread: Painting an old Stainless Steel Purex 60 SqFt Filter
    Largo, Florida
    Default Re: Painting an old Stainless Steel Purex 60 SqFt Filter
    Painting won't cause it to explode! I can't even imagine what was going on in the mind of whoever originated that idea.
    I suspect it comes from information about painting significantly pressurized metal canisters. Specifically SCUBA tanks that typically are filled to about 3000psi. Some painting techniques heat the metal which can weaken it. Obviously not a significant concern with a filter that's going to hold 100psi or far less. Also, I doubt OP is talking about bake painting the filter.
    OK, that makes sense. Paint applied at high temps didn't even occur to me.
