The pool company just opened our pool and got the equipment working, including priming our pump. After they left, I was manually vacuuming to "waste" with the main drain closed and one of the two skimmers closed The other skimmer was the one I used to vacuum. The pump basket was full of leaves, so I turned off the pump, but couldn't open the lid. I figured hubby could help the next day. I disconnected the vacuum hose, but did not reopen the main drain or skimmer. Then I left to take kids to soccer. When I came home, hubby opened the pump basket, cleaned out the leaves, put the lid on, and started the pump. I was down by the pool waiting for water to come out of the returns. Nothing came out. Then I remembered that I still had the main drain and one skimmer closed. Would that have screwed things up?
We immediately stopped the pump, and I reopened the valves. However, we cannot get the pump to prime. We filled the pump basket with water, it stays full (which isn't normal, it usually gets sucked away quickly), put on the lid, opened the DE filter gauge to vent it, started it up, and the water gets sucked out of the pump basket but new water won't come in.
We only did this for two minutes at a time before putting in more water. I know you can ruin the pump seal if you run it too long without water. Does anyone know what could have happened? Are we just not giving it enough time to prime? I know the pool guy said ours is tough because it's higher than the pool. Or, did I not give it enough time to circulate after the pool people started it up? Because once I got the vacuum set up (maybe 2-3 minutes) I switched the multiport to waste. I'm so confused because I don't know what I did wrong. I don't know if they will come out without me paying them again.
