Results 11 to 20 of 21
Thread: Sizing a new pump
    lstinthot is offline PF Supporter Thread Analyst lstinthot 0
    Aug 2011
    Default Re: Sizing a new pump
    We live in Central Virginia. We have a hurricane season.
    ~36,000g IG gunite -- 2Hp Pentair UltraFlow filter pump - replaced with 2 speed 1 1/2 HP ultraquite pump -- 3/4 HP vacuum booster pump -- DE filter --K-2006 test kit
    mas985's Avatar
    Pleasanton, CA
    You can use this map to determine your vulnerability.
    http://www.vaisala.com/VaisalaImages...01997-2010.png
    Mark
    Aug 2011
    Looks like we are in the 9-12 region.
    Aug 2011
    Looks like these two pumps pull the same amps. The WFDS-4 is one HP and the WFDS-26 is 1.5 HP. The -4 costs about $75 more than the -26. Does it make sense they both have the same amp rating? Wouldn't make more sense to go with the 1.5 in my case then for the higher lift?
    Quote Originally Posted by mas985 View Post
    The UltraFlow is a high head pump so priming is probably as good as it gets with this pump. You can either replace the entire pump or just the motor. It usually makes more sense to just replace the motor if the wet end is in good condition and you don't need to change any plumbing. But since you have to change the plumbing anyway, it may make more sense to replace the entire pump. Either way is fine, it is basically an economic decision.
    However, when looking at a replacement, you need to focus on max head because that is the only thing you can go on for priming ability. The higher the pump head, the larger the impeller and more effective the pump will be at priming. However, in most pump lines, the max head is the same for the various HP ratings so you can lower the HP to save some on electricity costs.
    If you want to stick with Pentair, the Whisperflo is a good pump line but for priming reasons, I wouldn't go below 1 HP (full rated). So either the WFDS-4 or the WFDS-26 would be a good choice.
    BTW, where is your location and how much do you pay for electricity? A VS may or may not be a good solution for you.
    Aug 2011
    Will these pumps move water on slow speed in my application? I am figuring 50 Ft of head, looks like slow speed graph tops out at 22 lbs.
  6. #16
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by lstinthot View Post
    The WFDS-26 is an up rated pump while the WFDS-4 a full rated pump but other than the label, they are identical in performance. So it doesn't matter which you get. One of the problems with pump ratings is that it causes confusion.
    Yes, they will still move the water on low speed. But head loss is dependent on flow rate so on low speed, head loss is about 1/4th that of high speed. If you indeed have 50' of head on high speed, on low speed you would have 12.5' of head. But you don't need to figure head loss to know that low speed is always around 1/2 the flow rate of high speed.
    But because of the lift, you will need to always prime on full speed and then switch to low speed. The pump should not lose prime when shut off but if does, it will need to be started on high speed. If you get a two speed timer, that should solve any priming issues because you can always start the pump on high speed and then switch to low speed.
    Mark
  7. #17
    Aug 2011
    I installed the WFDS-26 today. Went pretty good. Took a little longer than expected to complete. The discharge pressure on high is 16# and maybe 2# on slow speed. Not sure what others are seeing for slow speed discharge pressure. I did change the piping on the return of the filter. It now comes out of the filter and goes back to the pool without going through the heater or clear water metal copper system. Very little water comes out of the vent when I open the vent on top of the filter in slow speed. I am returning to the bottom drain of the pool. We keep this lineup during the spring to help heat the pool. Have not tried going back to the return jets.
    Pump is significantly quieter then the ultraflow 2HP even on high speed.
    New filter elements will be in Friday.
  8. #18
    mas985's Avatar
    Pleasanton, CA
    Low speed will have lower pressure and theoretically should be about 3 PSI but gauges get inaccurate at low PSI. 1/2 the flow rate results 1/4 the head loss in the plumbing.
    But is the pump basket staying full between pump runs?
    Mark
  9. #19
    Aug 2011
    The pump started up immediately the following day. Pump was full pressure came right up to 16# . Best it has ever done. I'm thinking slow speed could have started moving water from the start.
  10. #20
    mas985's Avatar
    Pleasanton, CA
    As long as the the pump doesn't lose prime after being off, you can start it on low speed if you want.
    Mark
  1. Pump and filter sizing
    By wsommariva in forum Pool Equipment & Operations
    Last Post: 05-23-2011, 12:37 PM
  2. Pump sizing query
    By Sumo1 in forum Pool Equipment & Operations
    Last Post: 03-12-2007, 09:58 PM
  3. Question on PB's pump sizing
    By txborn in forum Pool Equipment & Operations
    Last Post: 10-27-2006, 02:26 AM
  4. Pump sizing for filter
    By derrikm in forum Pool Equipment & Operations
    Last Post: 09-18-2006, 08:05 PM
  5. Pump Sizing Question
    By liz+3 in forum Pool Equipment & Operations
    Last Post: 06-27-2006, 10:45 PM
