Re: First post! A few testing questions...
Henrys514
Hi everyone! I have the Aqua Chem drops test kit. I know I should be testing my water for pH and Chlorine everyday, but what about the other parameters (TA, Calcium, CYA)? Once per week, or after a lot of rain?
Monitor CL and pH every few days (ideally daily, but most people including myself don't do that!)
Also, the instructions on the kit say that the color of the chlorine test after 10 seconds is Free Chlorine, and the color after 2 minutes is TC. Is that total BS?
Pretty much. The OTO test will only accurately test TC! If you want to test FC you need to use a DPD or FAS-DPD test.
I'm not sure if this is the right place for a CYA question, but I'll ask it anyway. We have a 12,000 gallon IG exposed(no pool enclosure=lots of junk in the pool) concrete pool. We live in Central FL, so it's pretty hot in the summer and gets sun all day. What's a good CYA level for us to have? I'm thinking maybe 60ppm? That would be a minimum level of 5ppm FC, right? What's a "safe" chlorine level to swim in (ie, what won't discolor clothes, etc?)
30 to 50 ppm should be fine and keep you CL at 3-6 ppm. "Safe" levels really depend on your CYA. If the CYA is high then more of the chlorine combines with it and is not as active so you need more in the water to have enough active reserve.
Looking forward to learning a lot here!
Hope this is helpful!
