Thread: Is it OK to open my pool in late June instead of May in Iowa?
    Apr 2014
    Des Moines, IA
    Default Is it OK to open my pool in late June instead of May in Iowa?
    I am a first time pool Owner. The reason I want to get my pool opened late is because I will be out of the country for 3 weeks starting end of may and returning June 20th. Is there something I should do in May though to ensure an easy opening? Pool was professionally closed and have a cover on it.
    Thanks for the help.
    Default Re: Is it OK to open my pool in late June instead of May in Iowa?
    You may want to add liquid chlorine and then re-cover to prevent UV rays breaking down the chlorine. Otherwise, be prepared to open to an algae bloom and adding lots of liquid chlorine/bleach.
    Apr 2014
    Des Moines, IA
    Thanks for the response.
    Do I need to run the equipment like filter, pump and stuff to let the water and chlorine mix or just drop a certain amount from the corners and close back?
    If you can run the equipment, I would do all of the following:
    1. Begin circulating the pool.
    2. Using a cheap OTO/phenol red kit, make sure the pH is between 7 and 8. Add bleach till you reach a dark yellow result on the kit.
    3. If you can, uncover a portion of the pool near a pool return or eyeball. If possible, adjust the eyeball to 'riffle' the water. Why? Chlorinating old water can produce 'chemical smoke' from the reaction of the chlorine with the dirt. This 'smoke' (volatile chlorinated organics AKA disinfection by-products or DBPs) can (a) damage the cover and (b) remain in the pool until the pool is uncovered.
    4. Continue chlorinating till the water is crystal clear and no slime or goo is felt or seen anywhere.
    5. At that point, you're ready to 'prep' the pool water for 'warm storage'. But you've got choices to make. Chlorine will NOT reliably keep your pool for 3 weeks when the water temp is 75 degrees or higher. There are 4 available steps you can take, singly or all together: use polyquat, raise borates to 60 ppm, lower phosphates to below 200 ppb, add copper algaecides. The first 3 have no negative side effects; copper can stain pools and turn swimmer's hair green.
