Thread: Issue with Sand?
    Default Re: Issue with Sand?
    Adding DE to a sand filter is sometimes suggested as a means of determining if your filter is working properly. If it isn't, then changing the sand isn't going to do anything for you.
    Apr 2014
    richmond,va
    Turns out the pipe inside the sand filter is broken in multiple places. The cpvc it is made of is not readily available in that size and the whole unit w/laterals is $75.00. Anybody know if I can 1 1/2" sched. 40 instead?
    18x34 22k gallon IG, Vinyl liner, Hayward sand filter, Hayward Chlorinator, Pentair Challenger 1hp pump, LA Spa.
