Results 1 to 10 of 28
Thread: Replacing cartridge with sand
    May 2013
    Concord,ca
    Default Replacing cartridge with sand
    Is it possible and worth doing to replace my Hayward cartridge with sand filters? I heard they are better but I know nothing about it
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    Default Re: Replacing cartridge with sand
    I can't help you with how to replace it but will tell you that sand filters are WAY easier to maintain. I think you'll be glad you switched!
    Welcome back to the Pool Forum for another season!
    BigDave's Avatar
    I'm with Watermom, I love my sand filter. That said, why do you want to change?
    May 2013
    Concord,ca
    pool isn't all that clean and I read where sand is better but I don't even know where to start. If I have to backwash, don't know what to do and would have to be repiped which is not a problem. I just don't know if Im opening a can of worms Im going to wish I didnt
    BigDave's Avatar
    What kind of cartridges do you have? Many cheap knock-off carts don't do the job no matter how much they cost. Filbur, Unicel, or OEM are the only ones recommended here: Recommended equipment for new inground pool.
    The advantage of sand over cartridge is the ease of cleaning the filter. For a sand filter, you simply turn a handle on the top of the filter a couple of times. The whole process takes about 2 minutes tops. Simple, simple. Personally, I will never have anything but a sand filter.
  1. Sand vs Cartridge filter
    By Reefdiver in forum Pool Equipment & Operations
    Last Post: 07-27-2011, 10:57 AM
  2. Replacing sand in my sand filter?
    By Txboynjgirl in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2011, 10:30 PM
  3. Sand to Cartridge Filter
    By PowerOut in forum Pool Equipment & Operations
    Last Post: 06-05-2010, 08:28 PM
  4. Replacing cartridge filters with generic brand
    By kearpaul in forum Pool Equipment & Operations
    Last Post: 09-20-2007, 07:01 PM
  5. Sand vs. Cartridge
    By hunter580 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-23-2006, 03:20 PM
