Results 11 to 20 of 28
Thread: Replacing cartridge with sand
    BigDave's Avatar
    Default Re: Replacing cartridge with sand
    Earlier you said that the "pool isn't all that clean" is the reason you are considering filter change. I thought that meant water quality (to me: little tiny stuff in water that makes it look dull). Did you mean something else by clean?
    No thanks needed (but appreciated), I like to help.
    And, Dave, we appreciate all the help you do give! Thanks!
    BigDave's Avatar
    Right back at you Lisa.
    May 2013
    Concord,ca
    what I meant was sometimes the filters seem like they don't do enough to keep the pool free from debris. The sweep works fine. Thanks, Dave
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    You could either have inferior brand cartridges, you are not cleaning them correctly, or your cart is too small for your pump.
    A properly sized cartridge filter, properly maintained, should perform better than a sand filter but not as well as a DE filter.
    Most people here don't like them because they are tricking to clean, but those who figure out how to clean them well, and with little effort, swear by them.
    May 2013
    Concord,ca
    I have decent cartridges but I need to find a better way to clean them. I saw a device where you lay the filter down in a tray and run the spray nozzle over them, plus I may need to get rid of a couple. How long are they supposed to last if cleaned twice a year? Thanks to all Dave
  7. #17
    BigDave's Avatar
    Have you seen PoolDoc's thread on Cleaning your Cartridge Filter without Damaging It!?
  8. #18
    Largo, Florida
    Quote Originally Posted by dansdad View Post
    Twice a year? I clean my cartridge weekly during the summer and fall. Twice a week in the spring. Once a month (roughly) in the winter.
    I've never had a cartridge get ruined but after about a year the "clean" filter pressure ends up about 10psi higher than the "clean" pressure was when I bought it. I replace mine roughly every 18-24 months.
  9. #19
    May 2013
    Concord,ca
    just as you mentioned it, I looked and ordered cleaner for the cartridges. Will be ready for summer. Thanks Dave
  10. #20
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by kelemvor View Post
    Your cartridge filter is obviously way too small for your pool. A properly sized cartridge system should only need to be cleaned once per year. Also, frequent cleaning is probably the reason you are replacing them so often. I have had my cartridges for 8+ years, clean them only once per year and the filter pressure never gets more than 1 PSI above the clean filter pressure.
    I am also one of those people who would never trade a cartridge for any other filter type. I just think cleaning it once a year is far easier than backwashing many times per year (my parents had a sand filter).
    Mark
  1. Sand vs Cartridge filter
    By Reefdiver in forum Pool Equipment & Operations
    Last Post: 07-27-2011, 10:57 AM
  2. Replacing sand in my sand filter?
    By Txboynjgirl in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2011, 10:30 PM
  3. Sand to Cartridge Filter
    By PowerOut in forum Pool Equipment & Operations
    Last Post: 06-05-2010, 08:28 PM
  4. Replacing cartridge filters with generic brand
    By kearpaul in forum Pool Equipment & Operations
    Last Post: 09-20-2007, 07:01 PM
  5. Sand vs. Cartridge
    By hunter580 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-23-2006, 03:20 PM
