Thanks got responding I think I just need to replace my filters as there are two from the original setup and pool is 7 years old. I'll start fresh with new filters and then keep them clean
13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
I only trust the k-2006 titration is better for me
I have two sets. I use the old set for opening and change it out after two weeks. Then my good set lasts about 2 months.
does everyone s cartridge filters last before being replaced? one season? 2 years? I'm really wondering
I have one set of cartridges going on 9 years now.
The only reason you should need to replace your cartridges is because they are torn which is often caused by cleaning or they are so clogged that you cannot clean them anymore which is often caused by bad chemistry. So the key to extending the life of the cartridge is keep the chemistry in balance and avoid algae blooms (I have had one in 9 years), and go with a large filter to minimize cleaning and the chance of damage. Also, a small pump helps to reduce the flow rate through the cartridge filter.
Mark
thank you ...im getting a plethora of info here
