Re: New to pools. Help with Filter operations.
Hi Summer.
Which Taylor kit do you have? If you don't have the K2006 or K2006C you probably don't have the key test: The FAS-DPD test (DPD is a different test).
You'll need to spend some time educating yourself on the B-B-B method. Start by reading EVERYTHING you can on Ben's forum: www.poolsolutions.com to learn B-B-B.
