Yup.. don't do that unless you want a new pump!
If things are that bad, you should probably use a leave rake instead of a vacuume.
Robert
Robert
thanks for the quick answer!
I tried that a couple of weeks ago...took about 10 seconds to gunk everything up. I had to take my pump apart and clean all the crap out of the impeller to get any water flow through the pump. I do NOT recommend it!![]()
Sherra
Kershaw County South Carolina
(previous AG pool owner)
Better idea: They make a vacuum cover for your skimmer that covers the whole basket in the skimmer, rather than pull out the basket and put the hose in the hole. That way, the skimmer basket catches all that junk, not the pump basket.
Here's one reference to them--the Hayward brand
http://www.poolsupplies.com/Product_...mers_Wall.html
They are called "Skim-Vac Attachments"
The Skim-vac attachments seem less expensive, but if for some reason they wouldn't work, maybe something like this:
http://www.bestbuypoolsupply.com/lar...-canister.html
or this:
http://www.bestbuypoolsupply.com/hay...-canister.html
Dave C.
