Closed Thread
Thread: Need tips for replacing IG vinyl liner
    Dec 2005
    Athens, Georgia, US.
    Default re: Need tips for replacing IG vinyl liner
    I live in Athens, GA and just replace my liner. My pool is 18x36 in-ground. I decided to use the lighter weight liner due to the 90 degree corners in my pool ( the lighter liner "hugs" the corners better). I also added wall foam as my pool did not have this installed. If I had to do it over I would have added the wall foam on the sloped surfaces as well. I also had a "liner lock" installed all around the pool. The color is a deep blue pattern on the floor and the walls (the style was called "Cambridge"). I paid $2400 for all of this. I am very happy with the result.
    Bill Marshall
    Default First estimate
    I got my first estimate: It was $3,200 to replace/install the liner and put in new faceplates. He says the job should take about 3-4 days — including about 18 hours to refill the pool.
    The installer talked about 30 mil vs. 27 mil thickness. Is there a performance difference?
    Also, how should I coordinate the installation of the new liner with the opening of the pool? After the liner goes in, turn on the circulation system and balance the water?
    Thanks,
    Z
    Waterworks is offline In the pool biz Thread Analyst Waterworks 0
    Default
    We replaced a 16' X 40' L shaped liner recently. The price was $3700 CAD. This included repairing quite a few holes in the floor of the pool, saving the existing pool water in 2 large 'quick-set' pools, measuring and replacing the liner, new face plates, liner-lock and balancing chemicals if needed. I hope that helps you.
    Many '30 mil.' liners are actually 28 mil. thick. 27 and 30 mil liners are so close that you probably won't notice much of a difference.
    Once the liner is installed, hook up your plumbing, shock the pool, balance the water and you're all set.
    Brad
    www.waterworkspools.com
    Default
    I've gotten three estimates:
    $2,200
    $2,800
    $3,200
    All are pretty much the same: they offer to repair any damage underneath the liner as well as replace wall foam and faceplates. I'm leaning toward the middle bid, which includes a 1-year labor warranty from the local, family-owned company and a 15-year warranty on defects to the 30 mil liner by the manufacturer. The installers are a two-man team employed by the company.
    The company says the procedure will take about three days - not including the 21 days it takes for the custom-ordered liner to arrive.
    I appreciate all the help.
    Z
Closed Thread
