I agree that your numbers look good. My only comment is that if you find, once the heat of summer gets here, that you are having trouble keeping chlorine in the pool through a hot sunny day that you might want to bump your CYA up some. You may not need to but just keep it in mind if you start ending up with your chlorine level below the needed minimum (per the Best Guess Chlorine Chart) at day's end.
Good job!
