Results 1 to 9 of 9
Thread: Using PhosFree for algae control
    Default Re: Using PhosFree for Algae Control
    The Orenda PR-10000 which can be purchased for $46 per quart* or $135 per gallon* is very concentrated (70% lanthanum chloride by weight) where one quart removes 10,000 ppb phosphate in 10,000 gallons.
    Admin update: on 8/8/2014, with shipping added, the cost @ Epooldepot.com was $52/qt or $141/gal. This is still the best price I've seen online.
    It looks like that product may well be cheaper. I seem to remember the prices being higher in the past; am I mistaken about that?
    I looked up some of your posts on that product. You note that it produced severe cloudiness, which is what happened to me, when I tested one of the first products nearly 20 years ago. Does using the clarifier simultaneously prevent that? The product I used years ago also plugged the sand filter, and I had a hard time backwashing and clearing it. Did you notice any similar effects.
    I'm not sure why, but the Kem-Tek product produced no cloudiness when I used it. I even tried pouring it in a column in the deep end, so I could see the cloudiness better, and never did. I did not notice any effect on the filter or pressure. On a 200,000 gallon pool, it took a total of 26 quarts to read PO4 > 125 ppb. The largest single dose I added was 8 quarts.
    Some phosphate remover products contain a clarifier in them so that may be the case with Kem-Tek. I believe that the Natural Chemistry Phos-Free products have clarifier.
    Yes, using a clarifier should prevent or at least limit the time for any cloudiness. My pool cleared up very quickly once I added the clarifier and ran the filter 24/7. It was clear the next day, but I don't know when in that roughly 15 hours it actually cleared up (i.e. how long it actually took). Basically, the lanthanum chloride not only combines with phosphate in the water to form lanthanum phosphate but it also combines with carbonate to form lanthanum carbonate. This usually gets caught in the filter and if there is any additional phosphate then then carbonate is exchanged for the phosphate.
    I did not notice any rise in filter pressure and I have a cartridge filter, but it's oversized 4-cart 340 square foot total area for a 16,000 gallon pool. When I cleaned the filter, I didn't notice any unusual amount of plugging up. It has the normal mixture of mostly suntan lotion along with cedar needles.
    I'm not sure the more recent products have the severe side-effects I experienced, which has been limited to whatever product I used on that pool many years ago, and the Kem-Tek.
    But it did surprise that I did not see any cloudiness -- even briefly -- from the Kem-Tek product. Initially, it made me afraid the product wasn't even working, so I was careful to do pre / post PO4 testing to reassure myself.
    I should note that the product itself is a milky mixture, maybe like a water/skim milk mix. So when I poured it in, there was some haze from the unmixed product. But that disappeared as the product was diluted.
