Thread: Can't remove pool return winterizing plugs
    May 2014
    Colorado
    Default Can't remove pool return winterizing plugs
    Hello! I am trying to open my in ground pool, but no matter what I do I can't get the return plugs out! ! They are the kind that have a wing nut on the end and they simply won't budge. Does anyone have any tricks for getting them out?
    Default Re: Can't remove pool return winterizing plugs
    I dunno. I guess what I'd try first is
    (a) grip the wing nut with a large pair of Vise Grips, and then rotate the Vice Grips, OR
    (b) find a hex socket that will fit over, but engage, the wing nuts, and then use a ratchet handle.
    (c) use a new, sharp 1/8" or 3/16" split-point drill bit, and drill holes all around the through-bolt. Eventually, you'll either relieve the compression on the plug, or cut so much out that you can extract the bolt. Obviously, the pool has to be partially drained with this approach.
    . . . membership updated.
