Go ahead and test the pH of your fill water. If you already have water in your pool, you can go ahead and get some bleach in there (or 12% liquid -- either way) so it won't turn green while you are waiting for your plumbing to be done. It doesn't take long for a pool with no chlorine to start growing algae! You can just pour it slowly reaching as far from the edge of the pool as you can. Then, use a clean broom or oar or something to try and stir it around as best as you are able. Alternately, if you have one, you can use a submersible pump to move it around.
