Ready to go....getting liquid chlorine today. I will test water for PH before going to store. I will need stabilizer as well, correct?
Yup.
I added 1 gallon of 8.25% wal mart bleach and now have free chlorine of 6.4. I assume that will come down on its own? PH is around 8, acid demand says to add just 9 oz of acid. Pool is 10,000/11,000 gallons (estimate)
Without CYA, your chlorine won't stick around long. In fact, until you get some CYA in the water, you'll probably have to add chlorine a couple of times per day. How are you planning to add CYA? Buying some separately and just adding it or using dichlor for awhile which adds chlorine and CYA?
You can use some muriatic acid to lower the pH some. But, please read the sticky about using it safely in my signature below before using it in your pool.
Added cya this morning, will test levels later today
