Re: DE Inground Losing pressure
ok i replaced the leaky union after the pump basket, not leaks. Still losing pressure after about an hour then barely anything pumping loses primer, but check the video gauge drops when i shut it off. I know i put the new fins correclty inside the filter with new manifold and it all fit together perfectly no spaces tightened down. No leaks on outside just wondering would the oring inside the filter where grid manifold will make it lose pressure? http://youtu.be/fQvR3swDEzQ
