The heat (enthalpy) of dilution for some acids is given in this link. 31.45% HCl is around 10 so the heat of dilution is roughly 10 kJ/mol. 38.5% Sulfuric acid, by comparison, has a heat of dilution of around 28 kJ/mol so substantially higher. This link calculates the temperature rise for a specific example of adding acid to water and explains why adding water to acid is not a good idea. It basically has the water heat up so much that it can boil and splatter, causing acid to be propelled with it risking getting splashed with concentrated acid.
15.5'x32' rectangle 16K gal IG concrete pool; 12.5% chlorinating liquid by hand; Jandy CL340 cartridge filter; Pentair Intelliflo VF pump; 8hrs; Taylor K-2006 and TFTestkits TF-100; utility water; summer: automatic; winter: automatic; ; PF:7.5
I like adding the acid slowly to the pool all the way round and letting it fume, I grab my air guitar and sing "Smoke on the water"
