Re: Draining and replacing vinyl liner swimming pool water
Ben has already suggested you do a bucket test. I just have a comment to add regardless of what the bucket test shows.
If it were my pool and I had a CYA of 80, I wouldn't be using pucks at all, ever. I'd use bleach instead. Pucks will continue to add CYA and yours is plenty high enough already! Besides to clear a pool up, you can't add a large enough dose of chlorine with trichlor pucks.
You should be able to solve your problem by adding 7 gallons of 8.25% bleach at a time, and checking your chlorine level 3x / day. Your goal should be a chlorine level of 20ppm and each gallon of 8.25% should add about 2.84ppm of chlorine.
If you use 12% liquid chlorine, it will add about 4.1ppm per gallon and you'll need 5 of them to shock your pool (that's one full 5 gallon carboy).
40 gallons sounds like a lot, but if you didn't add it in large enough increments, your algae would just keep coming back. Since MY liner is old and faded, I'm willing to get my chlorine levels quite a bit higher to slam that algae to death.
Thanks everyone! I need to get some additional borax and try out the bucket test tomorrow. I'll post what I found out.
Ross
Well I didn't do the bucket test, but I did drain about 1/8 of the water out of the pool and replaced it....and then kept at the chlorine morning and evening, and now it is finally clear. Either at the end of this season, or at the start of the next I will have the liner replaced.....along with the water! That will help things, I'm sure!
Thanks for everyone's help, and keep up the great work on this forum!
Ross
Glad thinks worked out for you!
I love it when a plan comes together!
