Brown stains on stairs??
Ok....everything has been great up until now...
Chemistry is perfect for my level of CYA (CYA 30, FC 2-3, pH 7.2, TA 100)...18 X 40 IG Vinyl.....crystal clear water
Tonight I noticed that the stairs and skimmer plate below the water line is turning brown. It doesn't rub off......is this a metal problem???
I haven't filled my pool since the day it was initially filled in 2004. Once in a while I'll add and inch or so from my well when there's a hot spell or a "cannonball" party, but for the most part, the rain fills the pool up (and I end up draining).
Any advice on how to deal with this brown staining on my white stairs..should I be testing something or adding something to the water other than bleach??
Thanks in advance!
18 X 40 IG Vinyl
3 1/2' ft to 8' deep
Pentair DE Filter
400K BTU Pentair Minimax heater
